Manufactured Curvature 60 x 30 cm Porcelain Tiles In Brick Pattern
Re: Manufactured Curvature 60 x 30 cm Porcelain Tiles In Brick Patter
I did what thread was you reading put your glasses on you might see a bit better we can all be funny:lol: as you have been we are all in the same game so lets all look after each other when there is truth being told instead of slagging each other off.
Paul you have lost me now sorry, we are all in the same game, but what are you saying? maybe there is another thread I have missed, this is a real friendly forum full of good people trying to give advice. Can you explain to me what you mean?
We cannot say anything till we know what has gone on , what the tile is and what grout width is and what the lippage amount is. etc.
Dave this client was adamant on having a 1mm joint in a brick pattern and was told by the tile shop salesman that the tiles were pre sealed and the manufactures boxes were completely blank boxes nothing regarding recommend tile joint, nothing regarding sealing, nothing regarding not to be laid in a brick pattern, nothing on flexible adhesive, nothing regarding the microscopic holes in tiles that can cause grout haze on the tile surface just completely blank boxes.
Paul, you're still not explaining the situation very well mate. Have you fitted these tiles and now the client is unhappy with the result? And as a result has contacted the TTA?
ok.. so 3mm min on floors but can go smaller IMO.. just depends on tile and size of floor area but BS5385 states 3mm min..
Some polished porcs do require a sealer to close the open pores from the polishing process , so as to avoid grout grab.
Putting 2 tiles face to face will determine the amount of bowing and if excessive then i refuse to lay brickbond.
Yeah so the TTA say they don't give out information to none members well they did to this client and I know he is not a member.
All of above is common knowledge to tilers paul.. This is taught when learning the trade..
The grout grab can be removed but lippage is not an easy fix... is it bad..?
Ok Dave client inspected and accepted all effects that was in them floor tiles none of these floor tiles were condemn for fitting or were they condemn in being used in any pattern and no joint was specified on the boxes these floor tiles are EU / BS standard approved for fitting in any which way.
Cut my comments short on the reply damit. Either your not very good at explaining yourself or are taking the preverbial. Just stop talking in riddles man...
Paul Crosby,
Paul Crosby,
