Various Size Tiles.....Setting Out??????
ace ventura
Hi All, Just wondering if any of you have any tips for setting out when using various sized floor tiles.
Customer has supplied tiles, and when I have been up to check today their are 4 different sizes
500x500
100x200
400x300
300x300
Any advise as to where or which i should be using to set out on a 16sm2 conservatory floor that is on top of an extension!
Cheers,
Mark:yes::yes:
hello ace....if you call into your local CTD branch , they should be able to supply you with a pattern sheet, or if a kind member on here might have one they can email you...........also check with the supplier of the tiles, they might have one....
They are usually supplied in quantities to suit a particular pattern and if you deviate from this you could run out of certain sizes.......other wise you could have just done a totally random pattern..............good luck..
dry lay around 3 or 4 patterns, i mean 4 of each tile, in the centre of the room, then measure and work out which tile will be hitting the walls. adjust to get good cuts then hey presto!
1 room is fairly easy so dont worry, try doing it in a converted 75msq 5 room barn with curvy render walls!!
ace ventura,
DHTiling,
ace ventura,
DHTiling,
