Discuss Tiling over existing ceramic tiles in the Canada Tile Advice area at TilersForums.com.
klunk
113
Hi,
So i have a bathroom floor to tile the house is around 8 months old and they want the floor tiles changing but adamant dont want the mess of ripping up old ones,
Whats a good adhesive to use i was going use mapei flexible and some kind of primer after i have cleaned old tiles with sugar soap
Any tips welcome
On one
So what kind of uplift in the existing floor levels is there.........hallway carpet to bathroom floor?
On one
Its level with the carpet in the bedroom , they are happy to have a slight step created its a ensuite
So the existing floor is unlikely to have any overboarding if the the floor heights are level.
Your taking a risk overtiling, not knowing what the makeup of the subfloor is. If you were to take this job on I would be explaining to the customer that no guarantee's would be offered and that entails for you if it did fail.
klunk
113
I have explained im not happy overtiling but i have done a lot of work in past for them and members of their family so dont really want give them a flat no, regarding substrate i assume as its a new build and was tiled when built it was prepared properly so the floor was level
Spare Tool
If you really must tile over (not in any way advised due to relying on previous prep) prime and grip primer, Mapei or TM will give you the best bond to existing tiles...
Dumbo
Got failure written all over it , it's not anything like tiling over a solid screed floor .
Time's Ran Out
Sometimes you just have to take control - do it correctly or walk away - or you will find you don’t get any more work from them.
Nowhere have you said it’s a timber or solid floor.
F
Flintstone
Take them up of don't do the job, it's a new build and weather it be timber or a screed floor, they will have been fixed badly.
Reply to Tiling over existing ceramic tiles in the Canada Tile Advice area at TilersForums.com
