Gazebo
Greetings again to all you kind people on this forum, i have another problem with regards to tiling onto a lath and plaster wall, i am fitting a shower over bath (which will be used on a daily basis) one wall is brick and plaster the other is an internal lath and plaster stud wall. I am having to batten out the solid wall to house the concealed shower valve and pipework which i will then board with 12.5mm marmox board, but the lath and plaster wall is causing me a problem, it is possibly blown in a couple of spots but mainly it is the flex in the wall which i am worried about,will i be able to tile straight onto this using a SPF addy or will i need to tank it.?(only ever used Impey tilesafe before though) will the wall be strong enough for large slate tiles,.? would i be able to overboard the area of wall to be tiled with marmox or green moisture board maybe fixing with SPF and mechanically fixing into whatever studwork is there.? i am trying to avoid ripping the wall off as the ceiling has already been skimmed and painted and the wall in question is not due to be tiled in its entire length/height. the customer is proposing large format slate wall and floor tiles, (oh goody..! and tips with these would also be appreiciated, can you get reasonably priced calibrated,graded and sealed types of these.?)
Many Thanks
Gary.
:huh2:
Many Thanks
Gary.
:huh2:
