Shaving Down doors
UKTT Darren
TF Official Sponsor
Subscribed
Just thought i would start off this thread, thought it might be usefull for the new tilers, How much to take off a door, shave it down and replace, I would charge about £25/ £30
Hi Darren, firstly, thanks for the course ( finished yesterday ) secondly, have you got the name and possibly a link to the electric saw that you mentioned for this job.
Thanks in advance 🙂
Hi Alan,
Its called the Karlton door trimmer, not sure if you can still get them as they are a bit pricey, if you type it in to google, you can get some links there
Darren
Done my bathroom door the other day. i used a circular saw and stopped just before the end so as not to split it, then took the rest off with a hand saw didn't even take 5mins.
i use a riobi electric planer i got from b&q which since i had a load of other stuff to go through till never charged me for :angel_smile: so got a £80 planer for nowt lol
i luv b&q sooooo much
tony
and no i dont feel guilty:wink_smile:
GAZTIP. Before removing door to tile,place a pencil mark on door and one on casing/architrave,after tiling measure from tile to architrave mark,allow 5mm, mark on the door and plane.Always plane from ends to middle.:wink_smile:
a little warning for door choppers most older doors dont have a lot of wood (framework)to cut if you do go through just insert a fillet of timber, 40mm is plenty where you have lost the old one and stick an pin in place
works a treat on cheap doors:coffee:
Yeah B&Q are great, they nearly allways only charge me for the cuts and not for the wood itself. I love them too.
I've found the majority of doors I have cut are not square so i keep the cutting parallel to the bottom of the door and don't square it up.
good tips lads,doing a job today and had to take door off,cut it with handsaw and planed with lecy planer.Door was one which had pins in hinges,doddle to take off.
Shaving Down doors
UKTT Darren,
brian c,
UKTT Darren,
brian c,
