Discuss re-tiling walls plasterboard advice replace or add a backing board ? in the Canada Tile Advice area at TilersForums.com.
I
Isidoro
Hello
I am planning to refurbish the bathroom in my house. and I am not a professional
The walls tiles need to be removed and I am expecting the plasterboard will get ruined.
What is the best approuch
should I replace the old plasteboard with a cement board
(like backing board aquapanel from wickes)
or could I just put the the new cement board on top of the original plasterboard using screw and adhesive ?
I suppose the second will be easier
thanks a lot
Isidoro
I
ianflem
Re: re-tiling walls plasterboard advice replace or add a backing boa
You could just Replace the plasterboard with new plasterboard and tank out wet area's.
I
Isidoro
Hello Ianflem
thanks for your reply
So from your experience for walls iwould it be easier to replace plasterboard ? instead of put a backing board on top ?
thanks a lot
Isidoro
I
Ian
How is the current plasterboard fixed? Is it dot and dabbed to the block/brick or screwed to studs? Either way, it's a better job to replace rather than cover it over. Unless you are fitting heavy stone tiles, the cement board really isn't necessary, plasterboard is much cheaper also.
I
Isidoro
3 walls are internal so I am expecting are screwed but the external one could be dabbed
I suppose the dabbed one are difficult to remove.
the tiles are ceramic but they are a bit heavy: weight is 16 kg /m2 but I suppose it still possible to use normal plasterboard
however if I go for something like hardiebacker could it be pssible to replace the previous plasteboard for the walls ?
thanks a lot
623
Leeds
Yes is the answer.
Seems you want to use Hardiebacker, so use Hardi
I
ianflem
Isidoro,
Whether the boards are dot n dabbed or screwed to studs they can both be removed.
The weight you have advised will be fine on standard plasterboard.Cement boards can
be used if u wish.If it were me I would replace with new plasterboard and apply tanking
kit to wet area's (Shower etc).
Time's Ran Out
If your going to replace use a waterproof board or tile backer board.
DHTiling
You ask the best approach. A pro who knows how to give you that bathroom you need with that wow! Factor.
H
hedgie
I start my tiling tomorrow :sofahide: and for what its worth . . . . .
I took all the plasterboard off when I removed the old tiles. It had been dot and dabbed to the thermoblock walls and removing the dots/dabs took a long time but worth it. I rebuilt the surface with Tile Backer Boards and tile adhesive then tanked the whole lot.
Like most things - careful prep is the key.
Good luck. :juggle:
Reply to re-tiling walls plasterboard advice replace or add a backing board ? in the Canada Tile Advice area at TilersForums.com
