Discuss re-tiling walls plasterboard advice replace or add a backing board ? in the Canada Tile Advice area at TilersForums.com.
H
hedgie
H
hedgie
Not dot n dab - full cover with tile adhesive using 3mm square notched trowel. As the substrate was clean adhesion is good . . . . I hope - :yikes:
beanz
Points
1,003
Berkshire
Walls must've been good.. I'm surprised you managed to get a flat wall that way, to be honest. ;)
Ciscobloke01
Re: re-tiling walls plasterboard advice replace or add a backing boa
I'm looking to do the same shortly. Do I remove the tiles and adhesive fix 6mm Marmox board all over and use mechanical fixings also. Stud walls will be screwed to studs.
Is this OK for heavy travertine or do I need to remove all the plaster boards and re-board with 12mm marmox or Hardie backer ?
Reply to re-tiling walls plasterboard advice replace or add a backing board ? in the Canada Tile Advice area at TilersForums.com
