Discuss Long Straight Line of Tiles in the UK Tiling Forum area at TilersForums.com.
AndyLFC5
Basic question, but whats the best technique to get floor tiles running in a straight line, doing a long hall that runs into a long kitchen, so anything a bit out will show.
Cheers
Andy
GazTech
Cheers
Andy
or stick a laser line down the hall and mark it in pencil....Gaz
actiling
orite andy,
dependinding on what the floor is like,ie nice and flat..chalk line
little bit uneven..string line,this will help u with the heights but keep it quite tight.
......good luck
Rad2474
Dry lay them out down the middle stand back and look at them you should be able to see if they are straight.
cococay
Chalk line would be good as advised or if chipboard/ply or wooden floor you could nail down a couple of straight wooden battens.
Dan
Admin
Staff member
Points
1,318
Staffordshire, UK
I'd string a line down on a grout joint (after working out where your cuts will be and making sure they're easy to cut and nice looking) then use a straight edge or a couple of levels and pin them down with a box of tiles on your line and then you know your sticking to your setout.
NickH
Points
388
I've used a string line in the past but now would always use a laser. I use a PLS2 and you can set it up high on a tripod or magnet it onto a long spirit level and clamp that to something . However you set it up its easy to set out your line.
E
enduro
Little tip if you use a chalk ping ling, when u have chalk line on the floor spray with hairspray and it wont rub off.
Reply to Long Straight Line of Tiles in the UK Tiling Forum area at TilersForums.com
Hi, I'm new to the forum and fairly new to tiling, my only previous "proper" job was my recent...
