Discuss large format tiles & uneven walls in the UK Tiling Forum area at TilersForums.com.
Matthew77
Hi all
I'm starting a job tomorrow with some large tiles 550 x 320 & the walls to be tiled above the bath are quite uneven as they are rustic old cottage walls. (when putting the length of my 6ft level on the wall i could get my finger behind it in the middle) so that must be 10-15 mm
I'm going to use a 12mm trowel with some rapid set flexi addy, but was wondering if you might have some tips or advise for tiling on not so flat walls
thanks Matt
DHTiling
might give this a go, sounds like a plan
If you go the skim in with normal rapid set then you will have to leave to set, as it does 6mm and if you go much deeper it will shrink as it dries...
So by leaving it to set then if it does you will be ok for your tile bed as long as thts within limits...but this way will add time to your job..
Reply to large format tiles & uneven walls in the UK Tiling Forum area at TilersForums.com
Hi, I have 45m2 of 1.2 x 1.2 Mirage 9mm floor tiles to lay. Never done this size before. I’m...
I’m tiling a ground floor of a house approx 120m through a ground floor with 5 doorways in the...
Hi, I'm new to the forum and fairly new to tiling, my only previous "proper" job was my recent...
    Votes: 5 5.0%
    Votes: 8 8.0%
    Votes: 6 6.0%
    Votes: 24 24.0%
    Votes: 14 14.0%
    Votes: 28 28.0%
    Votes: 3 3.0%
    Votes: 2 2.0%
  • Tilemaster /Kelmore
    Votes: 19 19.0%
    Votes: 18 18.0%
    Votes: 11 11.0%
    Votes: 5 5.0%
    Votes: 3 3.0%
