Discuss Help in the Australia Tiling Forum area at TilersForums.com.
py rookie
hi there ive seen a hallway floor this morning that the customer needs tiling she wants a boarder around the skriting board and full tiles in the middle,its a L shaped hallway,this is my first floor with a boarder,do i set out full tiles first then boarder tiles later or put the boarder in first around the skiting then full tiles
F
Flintstone
By boarder do you mean the same tiles just set out with a full tile in the middle and th same cut on both sides?
py rookie
Same size tiles yes,it's a L shaped hallway,so I don't put boarder tiles around the skirting first?where is the best pace to start on a hallwa?
Andy Allen
I thought you ment an upstand skirtng tile ?
Where you cut about 5 inches of a tile and use it as a skirting ..
py rookie
These tiles but with a plain face to go around the edges of the hallway,so I would set out as normal
White Room
Yes but just make sure your left with a decent cut which balances both sides of the field tiles.
Reply to Help in the Australia Tiling Forum area at TilersForums.com
Hi everyone, With a kitchen renovation, Mrs choose the white mirror quartz floor tiles from a...
Hello all, After years of abuse, the bathroom needed an overhaul from top to bottom. Out...
Hi all, Will I be setting myself up to fail if I use the Dunlop CF-03 Flexible Fast Set Tile...
Teejay
