glass tiles
C
cass
Hi was wondering if any one could help.Done a job last year installing colored glass tiles had allot of problems cutting was told in local tile shop that i could cut with my wet cutter.However when i was cutting the couler film on back would peel and the glass tile would chip.I had quit a knew blade on my cutter and the tiles were of good quolity.I have a job to do next week using glass tile again and wondered if anybody could give me some tips
Thanks for that i see what you mean 'but when i was cutting tiles they were chipping was i using wrong blade
i fitted a lot of glass last year on a job and found my sigma dry cutter was best for cutting them, cuts close to edge i scored then nipped off. worked ok on my job anyway.
I was told that i would need to use wet cutter in local shop.So it is ok to dry cut score and snap as usal.
Just use a Rubi with a new wheel.
You don't have to score hard but I find hand snappers best.
If the back colour comes off - and its usually white - use tippex.
Make sure you use a 'white' adhesive and try not to scratch the tile face.
glass tiles
cass,
cass,
cass,
cass,
