Epoxy grouting question.
StenhouseTiling
Hi, i just have a question but dont know if this is the correct place to post it. I have a big job tiling a factory floor of 1,550m2 useing 200x200 tiles. The grout i have to use is epoxy, could you give me a rough estimated time as to how many meters could be grouted in a day is im going to sub the job out to another tiler. Thanks
Depends on what epoxy your going to use,whatever you/they use it involves time patience and a lot of sponges.
Also depends on what tiles being used. If they were riven, stud face etc then it will take longer.
thanks. Its BAL floor epoxy. The tiles are more of a stud surface. useing a 4mm spacing.
sounds like a job for Berta, a few Bertas. How much time do you have to get the job done?
about 3 months. the quicker the better tho. theres me and another tiler laying the tiles. was going to get a guy in to do the job but was wondering what the time scale would be as i know where im at with what rate its worth.
I don't know bal products, so don't know how well it spreads or washes off. My experience is with Mapei, I would say around 25-30m2 a day for one guy. So it depends how many guys you put on the job
Thanks. The technical rep for BAL says its one of the easier types of epoxy to use. So hopefully he can get at least that coverage in a day. Cheers
Itd be quicker to have teams of two guys , one applies the epoxy while the other follows cleaning it straight away working their way through the pots. you'll need a ton of white emulsifying pads and if possible warm water.
missyT
On large areas we used to use a plunger cardboard cartridge to apply, you could use a mortar gun, then the Dixon floor scrubbing machine with a white circular pad to emulsify, then as mentioned above the Berta machine to sponge off. I am just finishing a steam room using Kerapoxy jasmine, a lot easier than the old stuff. Different methods on large floors, good luck.:thumbsup:
i used bal on a school toilet floor took me about 6 hours to do 18m, tiles were antislip so that didnt help but you need hot water,its like grouting with Silicon:mad2:
...and always wear Nitrile gloves, if any gets on your skin clean it off straight away or it'll burn. Its lovely stuff NOT.
Ive done a lot of Bal epoxy over the years, we use to damp the tile first, point then emulsify, wash off with hot water and a final wash with a spontex sponge. HOTTER the water the better
we used to sit the tub of epoxy in hot water before we used it, then it was all hands on deck, its not realy something you can do quickly so i would allow a bit more time to it
That sounds about right, its no easy quick job. IT takes time, and plenty of elbow grease.
StenhouseTiling,
NZ_Tiler,
StenhouseTiling,
NZ_Tiler,
