Epoxy grout
monkey
Have been asked to grout a 55 square meter food receptical tank with epoxy grout any ideas on wot to charge . GOD HELP ME THERES 9 OF THEM ALL TOGETHER . just want price to charge on one :mad2:
hi material (epoxy) and allow double your normal grouting time should cover it allow more if in doubt (does depend on your product some easy some hard to use) :8:
thanks jay what product would you sugest and what would you charge per square meter . taking into account ill be working of scaffold 4 mtrs high:yikes:
Why didn't the tiler grout? can't charge per mt, depends on the size of the tile as to how many grout lines there are. Do you know the customer? you don't want your first (?) job to give you grief. Not experienced in epoxy myself but would be wary on a job this size early in your career
hi tiles have been there for years they have a problem with water seepage. its a food prep factory for turning barley into malt .tiles were never grouted they just want to stop water .used epoxy before it gets messy .tiles are 150 x 150 cheers
Well a least it sounds like it doesn't have to look as good as a normal job, give yourself three days (complete guess on my part) and see if it's worth doing the others. make sure customer supplies grout or pay as you use it , because it will be expensive if you miscount!
laticrete sp 100 is easy to use follow directions use warm water its rec for food prep areas and acid proof price will vary on time not a job for virgin tilers :8:
Epoxy grout
monkey,
bighen,
monkey,
bighen,
