DeWalt D24000 Wet saw
Hi guys and girls,
Has anyone used or know anyone whos used the above saw and what its like. Have 66sqM of Large format Travertine to put down and only have a Briccollina - although good, the tiles are a bit large for its base. Any others that are good alternatives?
Cheers in advance.
CAS Tiling:8:
just ordered one from dave at tradetiler same as you got a large job to do been told its the best wet saw around a bit pricey at £700 but if it saves time it will be money well spent! let you know tommorow when i get it how it cuts !:thumbsup:
dave the cutting wheel on the dewalt 24000 will it cut all tiles or will i need extra discs for it?
Have a dewalt for about a month, Have done over a 100m of trav with it and it is very good,(it does leave the underside of the tile very wet but this is a small problem)I'm very happy with it and the service from tradetiler , the blade by the way will cut everything.
hi
If you don't mind cutting outside, use a mini grinder & turbo blade.
Fraction of the outlay - but depends as to how much tiling you do to justify the cost:thumbsup:
Plus you don't get wet - only choke to death:lol:
A dry cutting grinder will not cut a piece 10mm wide off a 600x600 trav tile!!!
Your obviously not trying hard enough.
Use a solid bed, sand under tile & voila:thumbsup:
Get the occasional break, but no different to overhead cutter - depends where the natural fissures are in the travertine.
ject05,
bighen,
ject05,
bighen,
