Guest viewing limit reached
Decoupling membrane needed?
Brody29
I have 2 rooms to tile with ceramic tiles 15 x 60 cm tiles. There is a sand and cement screed of about 90mm thick with ufh heating pipes set within. One room is approx 5x5 metres , the other joins this room and is a hall at 1.2 x 4 metres, there is an expansion joint between the 2.
Would this require a membrane and is there anything else you can recommend i may need?
Many thanks
Mark
No need for a membrane - just carry the expansion joint through the tile.
Thanks guys , there is a 25mm celotex upstand around the slab, so if I add an expansion joint Between rooms and around perimeter, that should allow for movement all around.
Am I right in assuming I just need a watered down pva solution on the screed, and then can just spread adhesive straight on once dry? Do I need any special adhesive due to ufh?
Many thanks for advice
Hi Julian , why would you not apply pva solution ? The house is a new build and the slab is quite dusty.
Tiling on Underfloor Heating
UK Tiling Forum; UK
Brody29,
Uheat - Jake,
Brody29,
Uheat - Jake,
