Riker007
This is linked to my earlier question about the notion of emulsion paint as a primer. I sanded 70% of the area of where the first line of tiles were going, then stuck on the tiles. This was a test, naturally. I had four tiles up, and let each one set for different periods of time ranging from 15 minutes to an hour and a half. Each one the layer of emulsion peeled right off onto the back off the tile, surprise surprise..
So, my question is, since I got about 12 square metres worth of emulsion paint to remove from the walls, and sanding barely scratches it off, it took an hour to do 2/3 of just one metre, and that wasn't hardcore removal either. I've heard that you can skim with adhesive, leave it 10/15 minutes, then scrape it off, the emulsion mostly should come off with it? Seemed to work very nicely when removing the tiles I was testing. Or, as a second choice, could I just get the plasterer back in to give the walls a new skim of plaster (onto already skimmed plasterboard) onto the emulsion paint. My concern then being of course that the plaster won't stick to the emulsion either..? Any ideas?
