Bathroom - Tile Edge Trim (Question)
U
Unregistered
Hi all, I'm currently tiling the bathroom and its my first time doing a full bathroom myself. I've done single walls before but never a full room.
My question is regarding the tile edge trim that goes around the window. After I use my diamond blade to cut the correct tile size when I put it against the trim (the cut edge) it will not lock or slip into the trim to hide the cut edge. (See pic 1)
When I use the good end of the tile it seems to fit perfectly and had a nice finish, but then of course my cut edge is facing the other tiles and thats not good. (See pic 2)
Or should my cut edge not be right against the edge trim but a couple of mil away so that you then grout between it ? (see pic 3)
Pic 1
Broken Link Removed
Pic 2
Broken Link Removed
Pic 3
Broken Link Removed
p.s. Sorry for the poor quality pictures
As Tommy says, most tiles have a "rounded" edge, so are slightly thinner at the edge.
From the pics, it looks as though you have a 7.5mm Tileasy trim. Try the 10mm :thumbsup:
Here are the pics to make it alittle easier for folk
Bathroom renovations
Hello,
Fixing bathroom trouble is not as easy as it seems to be. Expert guidance is very essential for properly carrying out all the renovation work. You should select a firm that has a lot of experience in this area of bathroom renovation.
Bathroom Tiling Advice
Unsolved
Unregistered,
Sam smith,
Unregistered,
Sam smith,
