Bathroom Final Decisions before I dare remove the loo
drewwiley
After loads of research and reading so many posts on here i just want to make sure i am approaching my project correctly, any advice is much appreciated.
Basically, we live in a converted barn, so its a bit weird !
Floor Construction
The existing floor is floating, DPM, Concrete, polystyrene, plastic sheet, chipboard. The previous owners had a leak but left the chipboard down !! so im replacing the lot as it bows. My new approach is this
DMP, Concrete , 50mm TF70 kingspan, visqueen HP Vapour layer, noMorePly 22mm t&g (this gets me to the correct floor heights). The chances are ill then lay a vinyl (no tiles). All joints will be glued and an expansion gap around the perimeter (later filled with a soft fill foam like up stand)
Wall Construction - this is my main worry
We will be installing a burlington hampton shower roll top bath against the back wall. The wall is double thickness brick (no cavity), there is then an internal blockwork wall inside the building with a 12" void between inside and out. The existing owners skimmed direct onto the blockwork and tiled direct on top of that !! not to many tiles were left on when we moved in!
After speaking to Hardibacker i am planing on tidying up the damaged plaster on the wall and mechanically fixing the hardibacker on top of the existing plaster. (NO MEMBRANES).
I will then tape the joints and apply RedGuard or similar (open to suggestions) followed by Mapei adhesive and tiles. do i need a membrane or will it cause me problems??
Not all of the bathroom will tiled so i will have to also install standard plaster board to the walls and skim that (before or after tiling? after i guess?)
Am i on the right track? Thanks in advance
For the walls, Ditch the hardie and use an insulation board, Xps board such as delta, Marmox, jackoboard etc. Save yourself a world of pain
Bathroom Tiling Advice
Unsolved
Tags Tags
bathroom
drewwiley,
Chalker,
drewwiley,
Chalker,
