Discuss Average meterage per day?? in the Canada area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
2020Tiling
What would be your average amount of mtrs you would fix in 1 day? Say for example flattish walls and 600 by 300 Porcelain, brick bond on Bathroom walls ? :smilewinkgrin:
CJ
Not really got an average.
Me, I seem to be getting slower as I get older in everything I do (Apart from my wifely duties :oops: So I'm told)
Why rush.......get it right, that' should be your first concern.
John Benton
Could be 3 could be 15 - All dependant on each job, just done a bathroom with 2 windows in, and that really slows the average per day down
Peter
Could be 5 one day and 30 next day, although would usually allow 3 days for an average 25m bathroom with rectified tiles and chrome trim etc. Bumpy whites in the same circumstances could be done in about a day and a half.
Time's Ran Out
With what you should be charging on a day rate you should be at least 8sq mts a day.
2020Tiling
Cheers guys! It took me 2 days to do a 8 mtr concrete kitchen floor with 600 by 300 porcelain tiles!!The floor seemed flat when I checked. I seem to be putting the first row on fine but then somehow end up building up the next 2 rows and back buttering to make them flat. Then get to a point where if I continued the tiles would be way to high? about an inch ? I used 3 bags of spf and seem to get this problem a lot and not sure what i'm doing wrong?
area tiling
All about prep work first, check your floor for dips and high spots with your straight edge , level them out choose a proper trowel size and away you go, get that part sorted and you'll tile your 8m2 before lunch , come back a few hours later and grout out!
2020Tiling
Always unsure what trowel size too use so do all floors with a 20mm solid bed? is this my error for 600 by 300 porcelain on a almost flat concrete floor ?
Reply to Average meterage per day?? in the Canada area at TilersForums.com
Dawz84
