Discuss 1st time tiling. Expansion joints? in the UK Tiling Forum area at TilersForums.com.
tilemark1
Hi
Just undertaken my first ever tiling job, in my own home.
I am tiling an en-suite shower, a 'C' chape. The walls are block and have been scratch coated. Got most of the work complete and am happy with it.
I left 2mm gaps between top row of tiles and ceiling, is this correct?
I left 2mm gaps between corner tiles, is this correct?
I am about to tile the bottom row of tiles and was wondering how much of a gap to leave between the bottom row of tiles and shower base?
Also, when fitting trim at the end row of tiles I butted the trim up to the tile leaving no gap. Somebody made the comment to me that I should have left a gap of 2mm here to fill with grout. I thought it looked neater just butted up against the tiles.
Your comment would be very much appreciated.
Anybody know what make of ivory silicone sealant I can use that doesnt go black after time.
DHTiling
Cheers, good to know I am on the right track.
I found a recommended silicone called 'forever ivory', which has microban in it.
I was also recommended Seal Guard for grout and tile sealing. It is an aerosol.
The sealguard is supposed to be good for grout etc......I have heard of the forever white so the ivory must be made by the same peeps.....
The sealguard i think you can spray on after about 15mins after grouting as well ....
Reply to 1st time tiling. Expansion joints? in the UK Tiling Forum area at TilersForums.com
Hello, I am a noob trying to tile our shower. Since the old tiles were taken off, some of that wall material has been taken off as well, so everything had to be smoothed. After smoothing with some...
  • Sticky
  • Question
