Discuss Backerboard or Ditra on Plywood? in the America area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
Hi everyone,
I'm having the majority of the ground floor of my house tiled (35m²) and I'm not sure which way to go from a subfloor / prep perspective. Here is the current set-up:
  • Suspended timber floor at 450mm centres
  • Wet underfloor heating system between joists in a pug screed
  • Tiny bit of deflection (<3mm) in one corner of the room which will be covered by kitchen units anyway
  • Large (~600x900mm) porcelain tiles to be the finished floor
Based on cost, floor build-up, ease of installation etc. I've narrowed it down to two options, and would really appreciate anyone's advice on which one to go for (or something entirely separate!):
Option 1: 18mm t+g wisa sprucefloor plywood on joists > 6mm backerboard > tile
Option 2: 22mm t+g wise sprucefloor plywood on joists > ditra mat or dura base > tile
(plywood will be sealed on both sides before installation)
Option 3: Knauf gifa floor instead of plywood - way too expensive and don't like that it is a floating floor rather than mechanically fixed.
I'd prefer the option with the lowest floor build-up, and the best structural stability - so here, option 2 wins. I'd also prefer to be doing as little screwing as possible into a floor with underfloor heating pipes in it! However, I've heard mixed opinions on using ditra/dura matting on plywood so would appreciate your input.
What does everyone think??
Reply to Backerboard or Ditra on Plywood? in the America area at TilersForums.com
Dawz84
