Backerboard or Ditra on Plywood?
Hi everyone,
I'm having the majority of the ground floor of my house tiled (35m²) and I'm not sure which way to go from a subfloor / prep perspective. Here is the current set-up:
  • Suspended timber floor at 450mm centres
  • Wet underfloor heating system between joists in a pug screed
  • Tiny bit of deflection (<3mm) in one corner of the room which will be covered by kitchen units anyway
  • Large (~600x900mm) porcelain tiles to be the finished floor
Based on cost, floor build-up, ease of installation etc. I've narrowed it down to two options, and would really appreciate anyone's advice on which one to go for (or something entirely separate!):
Option 1: 18mm t+g wisa sprucefloor plywood on joists > 6mm backerboard > tile
Option 2: 22mm t+g wise sprucefloor plywood on joists > ditra mat or dura base > tile
(plywood will be sealed on both sides before installation)
Option 3: Knauf gifa floor instead of plywood - way too expensive and don't like that it is a floating floor rather than mechanically fixed.
I'd prefer the option with the lowest floor build-up, and the best structural stability - so here, option 2 wins. I'd also prefer to be doing as little screwing as possible into a floor with underfloor heating pipes in it! However, I've heard mixed opinions on using ditra/dura matting on plywood so would appreciate your input.
What does everyone think??
hammerandnails,
hammerandnails,
hammerandnails,
hammerandnails,
