Discuss Fix backer board to thermalite in the America area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
Not sure if this forum is broken I can’t see most posts due to adverts, but I’ll give it a go.
Does anyone have any experience of fitting tile backer board to thermalite blocks? I have no room for battens so was going to dot and dab with mechanical fittings. Are thermalites suitable for spankers? If not what is best way to fix? Thermalites are no stronger than sponge for fixing!
Hey
You should be good with your plan, make sure you prime the thermalite before dot and dabing.
Fix the boards and ensure they are plumb and squared.
Once the adhesive is hard drill straight through the board and fix with rawl plugs and wedi washers.
Trigger
Not all tiling board manufacturers recommend dot and dabbing there boards. Check with the manufacturer of the board you intend to use.
Thanks for the advice. Yes it is recommended according to the website. It is q board from bandQ good price for 20mm 2400x600. My question is what mechanical fixing for thermalite as I bloody hate this blocks I can fix anything any sense. bring back dense concrete blocks that’s what I say:) brick it’s and their labourers my have a different view!
Reply to Fix backer board to thermalite in the America area at TilersForums.com
mcgtech
