Discuss Tiles falling off in shower enclosure in the Tanking and Wetrooms Forum area at TilersForums.com.
Pras
36
London
Hi, a few tiles keep falling off in the shower enclosure.
Any tips on the best material to use to replace the plaster. Pink area in the middle.
Thinking sand and cement (4/1 parts) or aquapanel piece screwed in.
thanks,
pras
Dave
1,000,000
Co.Durham
thanks,
pras
That’s knackered tbh , even got black mould growing, been a lot of water ingress.
A quick patch up won’t solve it for the long term.
GAZ5518
558
EPSOM
Unfortunately looks like water ingress..I would always advise against those kind of Tiles for use in a shower area as it’s very hard to make them water tight with such a tight joint which I suspect is where the main issue would be
I’m afraid Tiles off and re-tile is the only solution ..“.Impo”
GW
Reply to Tiles falling off in shower enclosure in the Tanking and Wetrooms Forum area at TilersForums.com
  • Poll
Hi Guys have a big gap above tray to fill 2cm high 1cm deep (3/4in x 1/2in) Any suggestions...
