Photos of your work! - Professional Wall and Floor Tiling Pictures (2019 Public Thread)
I apologize because it's still wet, I was in a hurry to go home.
So here’s a bathroom I’ve just completed in Surrey, it’s part of a much bigger project which has been running for a couple of years now, and will be several more months before it’s completed.
This Is the master ensuite and probably the largest bathroom I’ve done to date with a footprint of approx 6.5m x 7.5m
The material is a Florim 3.2m x 1.6m, it was an almost total solo install and was quite a challenge.
Obviously I had help taking material up to the room and I did have help for fitting of four of the panels, the rest however I completed on my own.
All adhesives and grout were supplied by Isomat.
AK25 on floors and AK22 on walls.
The two ends of the shower side walls are 8mm wide mitred pieces full height to avoid the use of tile trim.
The shower is 2.1 x 1.4m and is enormous, it’s fitted with Kerdi line linear shower gulley.
Floor tiles are 800 x 800 and having four different floor levels to work to made it challenging, hence not all floor reflections are exactly perfect.
Not much one can say after seeing that Marc. Bloody amazing workmanship seems a bit of an under statement 👍
View attachment 111259View attachment 111260View attachment 111261View attachment 111262View attachment 111263View attachment 111264View attachment 111265View attachment 111266View attachment 111268View attachment 111269View attachment 111270View attachment 111271
Amazing work mate that’s quality
Just a new house
Oh must have read it wrong, thought you said it was 2.25m
I quite often work within an hour of you, you’d be welcome to come along to see if you wish.
I’m actually in Orpington for next couple of weeks. 😊
No lol I’m only small so makes the cutter look bigger :tearsofjoy: and that would be great only 30ish mins away from Orpington
[automerge]1575228003[/automerge]
50m2 floor I’ve recently done in 280x1510 plank tiles really good quality tile Really pleased with the finish and flatness 🙂
I try to use it also to do this....🙂 a
Santa Claus has arrived
Dan,
demi34,
Dan,
demi34,
