Discuss Silicone joins at bottom of wall profiles in the Canada Tile Advice area at TilersForums.com.
R
rboy_44
Hi. Hope someone more knowledgeable than me can help. I am about to install a Merlyn Series 10 shower (sliding doors fitted in a tiled recess) and the instructions state that the inside of the vertical wall profiles need to be silicone sealed against the wall tiles (after the tray has been silicone sealed to the tiles all around the recess and left to dry). So this is fine, but what happens at the join at the bottom of the profile where the new vertical silicone meets the horizontal existing dry silicone around the tray? It’s my understanding that new silicone won’t bond well to existing dry silicone and if this is true then surely there will be a weak water ingress point at the bottom of the profile where the vertical and horizontal silicone meet? The instructions also state for the outside of the profiles to be silicone sealed at the bottom (going up only 50mm). Any help / clarification on this would really be appreciated. Thanks in advance.
Q
Qwerty
Follow the instructions as they're written. It will be fine. The important silicone joint is the tray to tile 90° joint. The silicone on the frame is to prevent water egress past the enclosure
R
rboy_44
Many thanks for this. So do I just smooth the new line of silicone (going down the profile) straight into the existing dry silicone on the tray to tile joint? Will this join not be susceptible to water ingress and let water get round the back of the profile?
Q
Qwerty
Not if done properly. The outside of the enclosure frame/ glass are the only joints usually that require sealing. Very rarely is the inside required or advised
R
rboy_44
Q
Qwerty
As I said previously, not if done properly.
I am well aware about Merlyn stating that, which is why I said very rarely is it recommended or advised, infering that most other manufacturers don't do it and it is just fine. I have fitted countless Merlyn enclosures over the years and not often do I silicone inside. Usually only on heavily profiled tiles
R
rboy_44
Again thanks, but I’d like to follow the fitting instructions all the same.
R
rboy_44
Thanks Chris. If you read the full post you’ll see that I’m just trying to follow the installation instructions, but they state that the internal vertical profiles need to be siliconed - this means running new silicone onto the cured silicone on the horizontal tray to wall joint. But as you’ll know, new silicone doesn’t bond to cured silicone so am wary of ending up with weak points at the base of both wall profiles.
Chris N
Will be fine...you're worrying unnecessarily.
R
rboy_44
Thanks but specifics would be more helpful, like do I follow the instructions or not? And if I do then do I just smooth the new silicone into the cured or butt it up against it? Or do I not follow the instructions and do something else?
https://merlynshowering.com/wp-cont...oor-fitting-instruction-MER-01-New-handle.pdf
Tried Merlyn and they’ve been next to useless. They suggested I do some research into how best to join new silicone to cured silicone and sent me a link to a specialist adhesive that I could try!
I’ve taken out the doors and removed all the existing silicone (as the original installer did a crap job with the install that resulted in leaks) and am about to reinstall so would quite like some certainty that I’m doing the right thing here.
Cheers.
Q
Qwerty
As a professional wet room and bathroom installer and approved Novellini fitter I've given you my advice
R
rboy_44
Appreciate your advice but it was a bit vague / confusing to be fair. You initially said to just follow the instructions and it’ll be fine, then later you said that most of the time the profiles don’t need to be sealed internally (but sometimes they do).
Q
Qwerty
No, I was referring to silicone onto silicone being fine (your original question), then added that internal sealant on the enclosure is not required as reiterated by another.
Reply to Silicone joins at bottom of wall profiles in the Canada Tile Advice area at TilersForums.com
Lowpaul22
