Silicon joins at bottom of wall profiles
R
rboy_44
Hi. Hope someone more knowledgeable than me can help. I am about to install a Merlyn Series 10 shower (sliding doors fitted in a tiled recess) and the instructions state that the inside of the vertical wall profiles need to be Silicon sealed against the wall tiles (after the tray has been Silicon sealed to the tiles all around the recess and left to dry). So this is fine, but what happens at the join at the bottom of the profile where the new vertical Silicon meets the horizontal existing dry Silicon around the tray? It’s my understanding that new Silicon won’t bond well to existing dry Silicon and if this is true then surely there will be a weak water ingress point at the bottom of the profile where the vertical and horizontal Silicon meet? The instructions also state for the outside of the profiles to be Silicon sealed at the bottom (going up only 50mm). Any help / clarification on this would really be appreciated. Thanks in advance.
Follow the instructions as they're written. It will be fine. The important Silicon joint is the tray to tile 90° joint. The Silicon on the frame is to prevent water egress past the enclosure
Many thanks for this. So do I just smooth the new line of Silicon (going down the profile) straight into the existing dry Silicon on the tray to tile joint? Will this join not be susceptible to water ingress and let water get round the back of the profile?
Not if done properly. The outside of the enclosure frame/ glass are the only joints usually that require sealing. Very rarely is the inside required or advised
As I said previously, not if done properly.
I am well aware about Merlyn stating that, which is why I said very rarely is it recommended or advised, infering that most other manufacturers don't do it and it is just fine. I have fitted countless Merlyn enclosures over the years and not often do I Silicon inside. Usually only on heavily profiled tiles
Again thanks, but I’d like to follow the fitting instructions all the same.
Thanks Chris. If you read the full post you’ll see that I’m just trying to follow the installation instructions, but they state that the internal vertical profiles need to be siliconed - this means running new Silicon onto the cured Silicon on the horizontal tray to wall joint. But as you’ll know, new Silicon doesn’t bond to cured Silicon so am wary of ending up with weak points at the base of both wall profiles.
Will be fine...you're worrying unnecessarily.
Thanks but specifics would be more helpful, like do I follow the instructions or not? And if I do then do I just smooth the new Silicon into the cured or butt it up against it? Or do I not follow the instructions and do something else?
https://merlynshowering.com/wp-cont...oor-fitting-instruction-MER-01-New-handle.pdf
Tried Merlyn and they’ve been next to useless. They suggested I do some research into how best to join new Silicon to cured Silicon and sent me a link to a specialist adhesive that I could try!
I’ve taken out the doors and removed all the existing Silicon (as the original installer did a crap job with the install that resulted in leaks) and am about to reinstall so would quite like some certainty that I’m doing the right thing here.
Cheers.
As a professional wet room and bathroom installer and approved Novellini fitter I've given you my advice
Appreciate your advice but it was a bit vague / confusing to be fair. You initially said to just follow the instructions and it’ll be fine, then later you said that most of the time the profiles don’t need to be sealed internally (but sometimes they do).
No, I was referring to Silicon onto Silicon being fine (your original question), then added that internal sealant on the enclosure is not required as reiterated by another.
Thanks for your comments Plan Tex Tiling - appreciate it.
jcrtiling - did you seal down the internal wall profiles and smooth the Silicon into the cured Silicon on the tray (as per instructions)? Or did you only seal the outside of the profiles?
The sealing of the internal screen profiles is purely cosmetic. Won't make a shred of difference if it adheres to the bottom bead properly or not.
I sealed inside and outside because im a rebel like that . Your main concern is about old and new Silicon it wont be an issue that is the point i was trying to make about sealing tray one day and fitting a screen the next . It happens all the time tilers finish tiling includuding siliconing and then plumbers come and second fix the bathroom including fitting screen .
rboy_44,
Dumbo,
rboy_44,
Dumbo,
