Discuss Setting out advice please! in the DIY Tiling Forum area at TilersForums.com.
macten
1,158
Nottingham
And Kudos for fixing them stacked!!
LEH
108
Oxford
Cool. I think I picked the stacked tip off someone in the forum too... :)
Final question- what size gap do you leave between tile and bath rim- just another spacer or more?
macten
1,158
Nottingham
2mm is about right
macten
1,158
Nottingham
Sure it won't be!
One thing I would recommend you do is when you remove the 20mm board off the cill, tile the window wall before you add the thinner board. You want it bang on level with the tops of the full tiles so take any guess work out the equation and build up to the required height after tiling.
LEH
108
Oxford
Yeah I was thinking it would be a major pain if it were a mm or two too low, given how close it is - will certainly do as you suggest!
Reply to Setting out advice please! in the DIY Tiling Forum area at TilersForums.com
