R
Reggiethethird
Looks awesome and a little depressing to see what we could have had.
Discuss Has an expert done this job? in the Canada Tile Advice area at TilersForums.com.
So where did the extra 10 bags of adhesive go? (I wonder)We had 12 bags of 25kg adhesive originally and ended up ordering another 10 bags.
Totally agree, I wish this was the colour we had for the rest of the floor, it's much whiter than we were expecting.Alternatively, the grout was very wet or he over wet the floor when washing off the grout the first time. The replaced tile looks better with the darker grout as you can hardly see it but ideally you want to see so it matches the rest
It's Grey and was the recommended by porcelnosa for the colour of tile we purchased.What is the colour stated on the grout bag?
The problem with the whiter grout line is that your eye is drawn to it and away from the tile, whereas the darker grout blends in to the tile colour and then you see the beauty of the tile
Yes it goes darker when wet. Is this a good sign that an enhancer can be used?Not a perfect solution but you may be able to use a colour enhancer on the original grout. Does it go darker if you dampen it?
From what I saw he was laying it thick on the floor and the back of the tile, hence using nearly double the amount of adhesive as was recommended.its a shame you have been let down . i dont think i would be paying for any of this job until you are satisfied with the floor if its all from the same company and icertainly wouldnt be paying 36 per metre for that, did you see how he was fixing the tiles, by that i mean was he using a trowel on the floor or was he putting spots on adhesive on the back of the tile
Fair enough, your comment actually gives me some confidence. Speaking to porcelanosa they suggest it should be an exact measurement to ensure the grout colour is matched when using using more than one mix on the floor. I assumed they knew what they were talking about as it's their product we are using.Farce! Then I've been doing it wrong for 44 years because I mix it to the right consistency .
That's interesting, in some cases he has used half a bag or even smaller amounts, depending on size of area.But then again you are using Butech/Mapei - always a bit hit/miss for consistency as the whole bag should be mixed to even out the polymers.
Occasionally you get orange bits in the Jasmine etc.
Reply to Has an expert done this job? in the Canada Tile Advice area at TilersForums.com
