XXL tiles - how to cut?
Grime
Hi All - a client wants his newly screeded floor tiled and is seriously talking about using massive ones: 2.4m x 1.2m.
If any of you have worked with tiles that big, what saw/cutter did you use to cut them?
The client wants 2mm grout lines - do you think there'd be any problems with this?
All advice appreciated. Ta.
Which tile manufacturer makes the large tiles your customer wants?
The quality, as with all tiles, usually comes down to who made them.
So the 2mm grout joint might be fine with one firm, but not with another.
So I just wondered. Not that I've installed any large tiles myself, I just thought the information would be handy for the others when they read the thread. 🙂
Lol. Sorry, I get you now. The manufacturer is Concept Tiles. The manufacturer's website says 2mm grout joints are fine, but I've never used tiles that big. I know the quality of the tiles and especially the sharpness of the edge ate the big considerations, but I'd still appreciate some advice or hear the experience of anybody who's worked with tiles that big.
@3_fall is pretty good with huge tiles 😉
Apparently your adhesive choice and mixture is important. And perhaps using some kind of levelling system. You need to guarantee 100% coverage still. Which is very hard to do with such a large tile. Apparently doing a sloppier mix is the way to go.
But like I say, don't listen to me. 🙂
Yes I did! 😛
images
That's a silly size.
Are we really just doing this to not see grout joints?
Are people who are buying them thinking it's going to fool other people into thinking they have a room built from solid marble? lol
That's the thing tho, the resemblance is incredible. I'll post a couple of pics, one will be marble and one will be porcelain.
I challenge you to tell them apart.
Ewwwww!
Is NZ Tiler using Porcel Thin there in his images? Looks the same stuff as you used on that posh job.
No, it's a Calacatta but not porcelthin. The largest they do currently is 1800 x 900,but that'll possibly increased to 2400 x 1200.
Is it from the same place though? I assume ray brands it Porcel-Thin when he gets it. Looks like the same print is used?
No idea where that is from but I highly doubt it.
Each marble has its own unique look.
Calacatta is Calacatta its distinctive, so doesn't matter who makes it, it will have a similar appearance.
I don't think i understand how it's made then lol
We need another thread for me pmsl
Nah that's what I thought.
It's a print. So that's the same print by the looks of it to me.
How porcelain is made and where is porcelain made are three different things haha
The xxl porcelain tiles are perfect copies of real slabs of marble.
They take a slab, and photograph it, they then 3D print the slab on to the porcelain.
Most often, the easiest way to create different designs of the same slab is to move the print along 10% and reprint. That way they get a tile that only repeats every so many tiles, but it all taken from 1 slab.
Help?
Yeah lol cheers. 😀
Somebody wants to take more pictures then because NZ Tiler's getting the same stuff as Ray is. If it's not the same tile, it's taken of the same slabs lol
Grime,
Old Mod,
Grime,
Old Mod,
