Discuss Is Ditra an overkill on concrete with ceramic tiles? in the Tiling on Underfloor Heating area at TilersForums.com.
bigdave1903
483
Aberdeen
Hi I'm going out to price a conservatory floor today. Customer wants electric ufh. Floor is concrete. I was going to lay marmox then wires covered in slc. Is ditra overkill or would you use it? Tiles will be either ceramic or porcelain.
Stef
Dave do you use CTD up your way??
If you do get the Jackon boards as a lot cheaper than marmox.
It will need to be 10mm boards for sticking to concrete, if any thinner they need fixed with screws & washers.
I wouldn't use Ditra as the thermal boards will give u a bit of decoupling from the base.
bigdave1903
483
Aberdeen
Perfect cheers. Yeah its ctd I use. They said they only do contract boards and hardi. Never used their contract board before so not sure what it is.
bigdave1903
483
Aberdeen
Yeah they are m8, good to use, I'm using them more & more over Hardie. Easier to handle & cut & as stated they will decouple slightly from the base.
Nice one. Just been to see it. It's actually a chipboard floor so just going to do the same prep but glue and screw 6mm board.
Reply to Is Ditra an overkill on concrete with ceramic tiles? in the Tiling on Underfloor Heating area at TilersForums.com
  • Poll
