Best Wet Room Tray/deck And Where To Buy From?
gordybaillie
Hi
I am quoting for a wet room which is currently a small WC but has space for a shower/wetroom area. The space I have available for the tray/deck is just over 1000mm x 800mm.
What tray/deck would you recommend (e.g. Impey?) and where is the best place to buy these from?
The walls in the room as also solid concrete as its an old building - can I tile directly on to these (as the previous tiler has done) or should I board first, if so what would you recommend?
Thanks in advance!
Hi
Thanks in advance!
Could you expand on that....
Sorry only just managed to get back online.
Yes we are putting in a new waste so we have a bit of flexibility in this.
Basically I am looking for recommendations on what tray to use as I have only done this once and used an Impey tray however is there any other makes you guys use for wet rooms?
If its a screed floor now I would be inclined to dig this out , fit waste, and re-screed to custom make the deck to the size you need or dig up all the floor and screed do the whole floor becomes a wet deck and do away with glass screen
Get an experienced installer in, take their recommendations and learn from them. I'd go with Schluter or Wedi myself. Both have foolproof drains.
Making your own tray/floor falls is also another option - and a hell of a lot cheaper and less chance of leaking especially if this is a downstairs room with solid floors.
What about the drying time? I like the idea of forming the try in sand and cement but have you got the drying time?
You can buy adhesive for this - look for a 'green screed adhesive or if you were uber confident, you can lay the tile in the sand and cement but better use tiles over 200mm for this. I have done many a job doing it with 150mm square tiles but you need the practice to get the falls correctly.
Just buy some green screed adhesive.
I can't get over some people's worry about x costing more than y.
Yet x installs far easier, far faster and with more peace of mind.
"Time saved = money made"
"Buy cheap - buy twice"
"Do it right - do it once etc etc etc"
(In b4 "a fool and his money..." 😛)
I can screed a wet room floor as quick as you can fit pre-formed tray - is that in your equation?
I love hand screeded wet rooms. Do share photos of your work as we all like seeing quality handmade work.
These are hand screened
my shower plates are all so.
my problem is that prepare them bricklayers 90%.
then I must correct the slope with rapid leveling, to proceed with waterproofing. 🙂
Perhaps you can, but then does that include the waterproofing and especially around the screed/drain junction?
Might be wrong but I would expect the most of Europe don't use preformed trays/decks.
With some research you will fit some bullet proof methods to tank/seal around fitting and drains
No I don't have any, is that a problem?
Next time I do one, I will gladly photograph the process. 99% of my time making my own falls for wet rooms/showers was before the invent of social media so it wasn't necessary to use photos as a proof of ability to do the work.
Maybe there are some hieroglyphics of me doing it though?
No, no problem at all. Always good to see members skills. I look forward to seeing your work.
Thanks for your help.
So it would appear nobody really uses pre-formed trays and you make your own floors. Does anyone have pictures of jobs they have done from start to finish?
Also who is best to contact for Wedi/Schluter?
I wouldn't say that was true Gordy, the majority will.
We have two members who keep wet room materials.
There's @Lee@TileTown in the Midlands. (Not 100% sure who's system he keeps)
http://www.tiletown.co.uk/en/
And there's Stuart @Stu Lilley from Lilley tile and Stone who stocks Schluter,
Both members know their stuff and would be a good place to start.
All New Lilley Tile and Stone
I used a Schluter Pre-Formed floor system, Kerdi Shower T I think it was (discontinued now I think) and it was very easy to use, first one I'd ever done (own wetroom) and it was brilliant, came with a full kit of waste, trap, pipe, kerdi membrane and Kerdi-Coll adhesive. Easy enough for a wet-room virgin like me to use.....but expensive if paying full price!
gordybaillie,
p4ulo,
gordybaillie,
p4ulo,
