Discuss Tile On Or Around Bath in the Australia Tiling Forum area at TilersForums.com.
J Sid
I was very glad I tiled the wall first on this job
Square back edge....
J Sid
Yes, oldie look, not my cup of tea but matches the other bits in room.
A spout out the wall may look better.
Stevev
488
Blandford forum
Tank wall where bath is going, fit bath with classy seal, silicone classy seal to tanked wall, tile down to bath and finish with bead of silicone, same for shower trays.
Sorry to ask , but, do you not tank down to the bath edge if you want to tank?otherwise what is the reason?
GAZ5518
558
EPSOM
If it's a normal bath and not a stand alone one I would always insist on it being installed first..( hopefully level)..Fill with water.. Just incase there's any flex or movement .. Then sillicon / seal/ prep prior to tiling..
Reply to Tile On Or Around Bath in the Australia Tiling Forum area at TilersForums.com
