1200x2400mm Porcelain!!
H
hmtiling
Hi all.
I've got a 1200x2400 porcelain job in January and haven't used tiles of this size before.
The tiles are 10mm thick which rules out using the Rubi Slim System.
I'm looking at the Montolit flash line and wondering if anyone on here has used it or could recommend anything else to use?
Many thanks.
Blimey , with tiles that big you just as well paint the floor and draw the grout lines on it ffs !
Diggy 😛
I don't often try and talk my way out of a job, but i did suggest a polished concrete floor on this!
🙂 certainly, certainly I did not know that there were porcelain from 1200x2400x10 .......... never seen
google traslate
I'd already looked at that, the breaking pliers with that system are for tiles up to 6mm thick. I can't seem to find the breaking mechanism in the video Antonio posted.
Well contact kwik Split, I'm sure they'll be able to advise
From what I can see with the Raimondai it's only a change of breaking pliers!
With the thinner stuff it's and actual pair of pliers.
With Antonios system it's a heavier duty clamp as opposed to pliers.
if it helps ,
if you decide to buy , remember to practice a lot , because it is easy to use , then when you get it, it will be very easy , pliers for thick coats do not find it difficult in internet google traslate
This system does up to 10mm
Graphics are poor but your best bet is still to discuss in person.
Here
attention , if you have to cut as 20x120 suckers you can not attack them !!!!! with raimondi climb with your feet and the bar remains stationary , with Montolit and sigma is not possible, you have understood ?
You are saying
Raimondai is a better system!
You are saying
can not make you understand ......... with the tiles tight , you can not fix the track , then with raimondi salts standing signs and also the tile , sigma and Montolit can not because he has to scroll engraving
I understand what you saying, I think! Haha
hmtiling,
Stef,
hmtiling,
Stef,
