Shower room pricing
R
RDTiling
Hi all.
As some of you will know (those that have stayed awake long enough to read some of my posts!), I started tiling in June of last year. Until now, I've been getting by with tile replacements, floor tiling and kitchen splashbacks etc (the small jobs that I'm assuming most tilers start out on).
A friend of mine has asked me to quote to for doing their shower room. I’ve attached a couple of pics of how it currently looks. It measures up to approximately 16sqm in total, including the floor, which is concrete.
Basically, the room is getting ripped back to the bare walls, being framed and overboarded, with either plasterboard or Hardie (I’m pushing for Hardie).
The wall that currently has the WC and shower on it, is to have a new shower tray fitted and then they want the width of the shower tray tiled with Mosaics (300 x 300 sheets) from Victor Paris (I don’t know the exact ones as they couldn’t find the literature from they were given, however I’ve asked them to check if they need sealed.) I’ve recommended a tanking kit on the wall with the shower and the wall to the right.
The rest of the room is to be tiled with plain ceramics (400 x 200) and the floor, despite the small size, they have gone with 600 x 600 tiles.
The wall that has the recess in it is being knocked back so that it is flat with no recess.
I’ve never really worked with mosaic sheets before (other than a small splash back in a WC). Although the finished article was good, it was painstaking and messy, as I had adhesive through all the joints and spent what seemed like an eternity to clean them out before grouting.
I was thinking that BAL Mosaic Fix would be the adhesive of choice for the mosaic fixing, however does anyone have any tips on fixing and setting out for Mosaic sheets, as whilst I can cut full tiles of the mosaic sheet, I’m assuming you can’t cut a mosaic tile in half for example?
Also, the wall with the mosaics are going to have two new hot and cold feeds, is the best way to cut holes for these to simply remove tiles from the mesh where the two pipes stick out the wall, as again I’m assuming you can’t (or shouldn’t try to) drill mosaic sheets?
For the rest of the room, I was thinking of priming with acrylic primer and using a standard setting adhesive from Weber, as I hate having to rush using rapid set, although I might use this on the floor so that I can grout the same day, after I’ve primed the floor with an SBR slurry mix.
So my initial thoughts for pricing for the tiling, including the mosaic sheets was £300, with materials one top of that. Does that seem reasonable? – I’m trying to avoid going in too low.
I just wanted to run through my thoughts and pricing with you guys before I formally price up the job (which is why I’ve posted this in the Arms rather than the main forum). If yout think I’ve overlooked anything please let me know – its my first shower room, so want it to be perfect.
Its situations like this where I'm hoping that ascess to the arms pays dividends so that I can actually start making some ££'s, as I know that over the last 9 months, I've been (majorly) under pricing.
If you are still awake after all of the above, thanks for reading and thank you in advance for your input.
Rich
That's £18 per metre. You can't do mosaics at that price.
for me, I would price for 3 to 3 1/2 days at your daily rate. I would price more than twice that!
Upvote 0
with mosaics you nomaly need about a 3mm trowl if you can get away with hence why you were getting into a mess
Upvote 0
do you think your ready to take on a job like this..?
why do you think you can't cut a mosaic tile in half..?
how long do you think it will take you to do the job..?
do you know a more experienced tiler that could help you out with this job....maybe split the money, and he could give you some advice with the mosaics..
£300 is a joke and you will make little or no money.....time to decide if your tiling for a living or a hobby for friends and family..
Upvote 0
As others have said....you are too cheap. My sq m price is more than twice yours (does incl mats though), but nearly always work on day rate though.
I would personally be boarding the shower walls with a tanking board rather than boarding then tanking.
Why the slurry coat? Is there bitumen on the floor?
Upvote 0
I agree with andy. Sometimes you nees to turn down jobs to maie sure you keep you reputation. Ive only been tiling just iver 2 years and I turned down stacks of work as I knew the jobs were too big for me. As irs a friend if you do a bad job everyone will know and yiu will fall out guaranteed
Upvote 0
Thank you to all who have replied to this.
To be honest a part of me says that I am happy to do. 95% of this room, it's the Mosaic bit I'm unsure of. Whilst I'm of the opinion that everyone has to do everything for the first time at some stage I'm thinking I should learn to walk before I learn to run, so on this occasion I'm going to turn down the job.
I'm on my mobile typing this and I know some of you have questioned some of my original comments. I'm not ignoring them and will reply when I'm in front of my PC later tonight.
Quoting is probably a weak point for me (as you've gathered from my pricing!) but I'll expand on my thought process later.
Thanks again for your input.
Rich
Upvote 0
mosaics aint all that tough with a good solid knowelage of tiling, bal mosaic fix is the boss when it comes to mosaics using a 3 or 4 mm trowel depending on the thickness of the mosaic,
youll be a busy fool at that price, id want 800 for it or i wouldnt do it,
Upvote 0
Imho it doesn't matter what everyone else would charge as its your friend's job and none of them would be competing anyway!
I'd normally be critical of novices like yourself taking work away from trained tilers but in this instance I'd rather encourage you to gain experience using this job and a reduced rate to improve your portfolio.
This forum is here to provide advice and if you post specific shorter threads I believe you will get a more positive response.
Good luck and continue to enjoy!
Upvote 0
Good to see you got out the right side of the bed today TJ..
Upvote 0
As TJ says I think you should have a crack at this.
If it's only the mosaic that's concerning you then spend a lot more time on this feature panel & get it spot on & learn from it.
I still don't particularly like fitting mosaics especially against the field tile & you have to build them out but if you don't ask you don't get & it will be good experience for you..
Upvote 0
Good to see you got out the right side of the bed today TJ.. 
I'am not sure if you are aware of my sleeping habits but if you are suggesting that I can be positive/negative in my replies by getting out of bed in a particular direction - then I have to make you aware that for the last 30 years I have spent the majority of nights on a setee!
Its the only way I can be sure of resting my back and waking up in such a pleasant and happy mood allowing me to provide witty and charming replies!
Thank you for your concern.
Upvote 0
Thanks for the additional replies.
it really is only the mosaic section that I'm concerned about taking on, but I know I'll need to take on mosaic tiling at some point.
It would behold experience for me, but I'll give it a bit more thought before making a final decision.
Upvote 0
Hey Rich,
firstly TOO CHEAP!
Now that's out of the way haha
you say width of shower tray is mosaic, is that one wall or two? (Sorry if I misunderstood)
have u used tanking kits before? If not I'd agree with PlanTec or go for tanking sheet on a roll like Schluter. (Schluter from CTD) much easier to use if you're a first timer and u can tile immediately. They have slightly different adhesive requirements tho.
Have a chat with Stef or Charlie 1 or any of the other guys from Scotland and try find going rates local to you. Being Edinburgh I'd imagine it'll favour u with slightly higher rates than elsewhere.
Does your friend know your skill level? If you're gonna attempt perfection does he realise it's going to take u a little longer? If you're competing against others for the job, yeah do mates rates to get work and the experience, BUT don't cut your throat. Knock 10% off not 50% otherwise u'll be under pressure before u even arrive. That's not advised especially as it sounds like your first major project. Be prepared for it to take longer than u estimate, cos it will! If it was me I'd be tackling the mosaic first, at any point do the mosaic butt directly against the wall tiles, or are they separated by the shower screen? If they do, then u'll have to consider any thickness differences, but don't be scared of them, they will bite if you're not confident. Treat shower as it's own job. Once the tough bit is outta the way it'll be all downhill!
Whilst i agree u should turn down some work because of individual skill level, I don't think so in this case. U've been cautious for a good while and not over stretching urself so maybe it is time to step up! But if you're unsure about something, STOP, get on here and ask don't plough ahead. U'll get more respect for checking than u will messing up!
Good luck Rich.
Upvote 0
Like that reply TJ,
Upvote 0
Fantastic reply 3_fall, it's much appreciated.
The mosaic tiles are only going on one wall (the one with the shower) so that it acts as a feature as you walk in the door (which is why I'm hesitating over taking this on, as I know I need to get it spot on for them).
I've never used a tanking kit before due to the smallish jobs I've done to date, so I'll look into the tanking sheets.
They know my experience level but seem happy to give me the opportunity to work in their bathroom and I've told them to allow me 4 days for the tiling (probably about 2 days of that will be be fixing the mosaics!)
The mosaic tiles will be separated by the shower screen, which thankfully takes care of the different thickness issue.
Thanks again for the response and I am warming to taking this one on - as it would be a cracking bit of experience for me.
Rich
Upvote 0
so you say your 'Quoting' the job for a friend......dose this mean your friend will be getting other quotes as well, or the jobs yours anyway.........just asking so John can carry on sleeping well at night...:smilewinkgrin:
Upvote 0
What size trowel did you use when you had problems with adhesive coming through? If the whole wall is being done then use a mosaic trowel, if it's a border or a feature between thicker tiles then search on here for the dog tooth method. Phil Hobson posted some pictures giving a step by step guide:thumbsup:
Upvote 0
No problem Rich,
thats supposedly why we're all here! TO HELP!
You say shower screen will mask the join between tiles and mosaic, is the screen full height? Prob not. Do they meet above it?
When working with mosaic I typically set out my sheets so that I can start around chest height. Couple of reasons, firstly it's a comfortable height to start at and you're not bent double or stretching which can lead to mis shaped mesh and obviously tiles. Secondly and maybe more importantly when a client first looks into room initially the eye is ALWAYS drawn to the brightest source of light (that's one reason why the window setting out is of utmost importance!) then they scan the room at about shoulder height, for me it's head height cos I ain't too tall! Haha so if your first four sheets between chest and just above head height are perfect they don't always inspect the rest too tough! So if u get a MINOR mistake or two u'll probably be ok. So set your sheets out just like any other tile, remembering to space between them. Draw your start line across wall at about shoulder height and HANG the sheet from the line down! don't put bottom on first and push up! It will distort. Then measure up or down (your choice) 2 sheets, then hang them from top down. Once in place gentle tap and flatten the sheet with the flattest grout float u have. Try and ensure u tap not WHACK! Watch the angle of your arm, make sure it's straight and not off on an angle. Trowel carefully, don't leave lumps of addy on wall. After nxt course of mosaic, go back on last course and wipe clean with DAMP sponge to clean any excess addy off. WORK CLEAN Bal's new Max-flex fibre (mosaic fix) is brilliant white and high grab, expensive but worth it! It's as easy as that! :smiley2:
good luck.
Upvote 0
He is getting one other quote too - the guy they have doing the plumbing, his brother is a tiler too, but they have use him before and thought he was expensive. From the area I saw of what he had done before in their kitchen , he did a cracking job of it.
Upvote 0
[MENTION=42603]3_fall[/MENTION] I've not seen the new shower cubicle yet, but you are probably better in the know about how high most shower cubicle screen are than me!
Thank you for the advice on fitting the mosaic's - it is very useful to know.
I think you've just established where I went wrong the last time with the mosaics - too much pressure was applied with my grout float (I think the phrase 'touch of an elephant' just about covers it). I did use a mosaic trowel though.
When I bought my rubi washboy, it came with a a big sponge thing that you use over the rollers and it also came with some sort of foam covered float, which I've never used - so I used that to flatten the mosaic splashback against the wall - i went on the logic that as it was larger than my grout float i could apply an even pressure across a larger area meaning it would sit flat. It did, just pushed a bit to hard!
Upvote 0
Rich
Your price does seem low and I know how awkward it is to price a job for a friend. The mosaics wont be a problem if you are over boarding that wall.
The wall where you have the recess might be a bit of a problem to knock back flat. That corner boxing by the toilet will contain an automatic air valve and will have to stay and be accessible.
Upvote 0
Shower room pricing
Best Bathroom Tiles
Unsolved
RDTiling,
thompsonbrown,
RDTiling,
thompsonbrown,
