Discuss Nicobond in the UK Tiling Forum area at TilersForums.com.
wetdec
Ultragrip and Aqua ultragrip are both good adhesives with huge slip resistance we use nothing but ultragrip. Plastic ply was their new product around 18mths ago to replace overboarding wood floors. A few on here have given it a go and we have used it on smaller floors with no probs. Make sure you get aquainted with the install instructions and you should be ok.
Plastic Ply
Davesax
i must comment i think the ultar grip adhesive is pants , imho
Ha , yeah I actually trained with it - I'm guessing it's the equivalent of Bal green star ?
So am I right in thinking that the plastic it can be used over floor boards ( with no movement ) and other surface like laminate . If so it looks far easier / practical , if not slightly more expensive , than using ply.
Colour Republic
have you used it republic would like to know , any good
Never used it, I've read some on here have and thought it was okay, sticky as hell so i'm told. Although the fact about laminate still stands.
It says it's a 'reinforcement board' which might suggest to some that it strengthens the floor for deflection which I don't think it does.
I can't slate it as i've never used it, but over floor boards I would have thought the floor needs to be perfect, I can't see how it would get over cupped boards???
Reply to Nicobond in the UK Tiling Forum area at TilersForums.com
  • Sticky
  • Question
