Discuss Nicobond in the UK Tiling Forum area at TilersForums.com.
Davesax
I'd be interested to know what people think of their products , in particular the adhesives . I'm thinking of trying the aqua ultra ready mix on a bathroom ( red bucket ) .
Also the plastic ply , is it ok to use over floor boards ? Does anyone use it .
Thanks a lot
nybor62
Points
1,083
rotherham
the plastic ply is designed to go over ply not floor boards, as for the adhesive if its for the floor then its no good. and to be quite honest not used a lot of nicobond products but what i have use i was,nt that impressed with
wetdec
Ultragrip and Aqua ultragrip are both good adhesives with huge slip resistance we use nothing but ultragrip. Plastic ply was their new product around 18mths ago to replace overboarding wood floors. A few on here have given it a go and we have used it on smaller floors with no probs. Make sure you get aquainted with the install instructions and you should be ok.
Plastic Ply
Davesax
i must comment i think the ultar grip adhesive is pants , imho
Ha , yeah I actually trained with it - I'm guessing it's the equivalent of Bal green star ?
So am I right in thinking that the plastic it can be used over floor boards ( with no movement ) and other surface like laminate . If so it looks far easier / practical , if not slightly more expensive , than using ply.
Colour Republic
I wouldn't go over a laminate with it as the laminate will be a floating floor:thumbsup:
nybor62
Points
1,083
rotherham
yes apparently you can put it over floor boards. personally im not convinced , im sure there is some on here who have used it. maybe wait for others to reply before you buy it
Colour Republic
have you used it republic would like to know , any good
Never used it, I've read some on here have and thought it was okay, sticky as hell so i'm told. Although the fact about laminate still stands.
It says it's a 'reinforcement board' which might suggest to some that it strengthens the floor for deflection which I don't think it does.
I can't slate it as i've never used it, but over floor boards I would have thought the floor needs to be perfect, I can't see how it would get over cupped boards???
Reply to Nicobond in the UK Tiling Forum area at TilersForums.com
  • Sticky
