Weber slc useby date
Wishiwasatoptiler
Hi
I have a few bags of weber fibre reinforced slc that i keep meaning to use, dated 13.9.17. Been in my dry store, not sure its worth using but need a few bags on bank holiday, would save a trip to topps, anyone any idea how long this gear stays useable.
Cheers
Hi
Cheers
Is that the manufacturing date or the best before ?🙂
Personally wouldn't risk it, might save you a trip to Topps but imagine going back Tues and its still like playdo
most slc and adhesive is 12 months shelf life and almost always date of manufacture printed on bag. id use it on a solid floor but not risk it otherwise
Thanks for the info fellas, think i will sack it off and go to topps, would hate for a good job to west for the sake.
Hope topps is ok as I never use it but I know its open tomorrow.
Cheers, i will head for that, need to tile tuesday, just a quick one, i never use rapid set addy, but in a bind with work so I need to tile and seal the porcelain that day, i wil be using clips, so will want the clips removed and cleaned before sealing, this is on an already hardie covered floor, will the clips knock off with out affecting the adhesion of tile, if i leave for 4 hrs or so.
Cheers, i will head for that, need to tile tuesday, just a quick one, i never use rapid set addy, but in a bind with work so I need to tile and seal the porcelain that day, i wil be using clips, so will want tge clips and cleaned before sealing, this is on an already hardie covered floor, will the clips knock off with out affecting the adhesion of tile, if i leave for 4 hrs or so.
4 hours should be fine this time of year
Wishiwasatoptiler,
Wishiwasatoptiler,
Wishiwasatoptiler,
Wishiwasatoptiler,
