weber adhesive
I used ot loads last year for a company I was subing to. mainly used their white spf. good suff no complaints.
Use weber.set rapid quite a bit, very good adhesive at a very good price (£** for 20kg). Only bad thing i'd say is the bucket time isn't good, small mixes only
used there spf white nice and creamy mix got good initial grab too great suction! pot life is about 2 hrs i recall open time about 20 mins. my mate got a great pallet deal on it couldnt fault it...
That's pretty much the only make I use. The rapid is very rapid - sets hard enough to walk on floor tiles within 2 hours - and the standard is very strong. Both the SPF types are a bit flexible so good for chipboard or under-tile heated substrates.
Definitely not cheap but consistent and reliable. That's more valuable to me. I've tried a few other makes and have always come back to Weber afterwards. Not so impressed with the grouts - happier with Mapei there - but there's not much in it.
The new "low dust formulation" packs are a lot less messy to use and I now don't feel the urge to wear a mask while mixing! Probably still should, though.
I've used the SPF, both rapid and standard, on porcelain, travertine, granite, limestone and gres with satisfying results.
weber floor flex levelling compound is awesome gear as well. flows really well.
the spf rapid low dust is ideal for floors but too rapid for walls.
weber set plus though is sound for walls because it has plenty of working time.
I use Weber a lot, and it's very good gear, never have any problems with it, and like Mapei, it's predictable in it's going off behaviour, the standard set is excellent for stone and wall tiles, it has good non slip qualities on walls, I would thoroughly recommend it Dave, and reasonably priced, especially the grey adhesive.:thumbsup: The SPF's are good too with good pot life and workability :thumbsup:
Yep use it LOADS, and their floor grouts. Really good, no complaints. Never had a duff batch, and the new "low dust" formula is a godsend!
there floor grouts are brilliant, used adhesive 2 weeks ago very slow going off 🙁
The only one I have had a go with is no good for you Gooner.........guess what it's made from......
the fast set pal on to a concrete floor strange and we were doin a kitchen floor into sitting room and furniture was all in the sitting room so we had to wait at least an hour and have 10am break lol till floor dried so we cud transfer all of the furniture from the sitting room to the kitchen
weber adhesive
Diamond Pool Finishers,
mistral,
mistral,
