uneven walls
saintdom
hey folks
have a wall that dips in the middle (dodgy plasterer me thinks) when a spirit is put verticaly on wall there is about an area of 2 sq feet that dips in about 4/5 mm , question is can i fill this with extra adhesive , acting like a skim coat then tile over.
ta much:thumbsup:
yes you could do that or use builders fastset as its cheaper and also dry,s out in about 3hrs for you to then tile.:thumbsup:
cheers for the reply brian, what does the fastset stuff come in, tub or bag. any ideas where to get it , i need it first thing really.
cheers again:thumbsup:
i had job the other week with same problem dodgy walls client didnt want me to be to fusy so i used a 10 mm wall trowel instead of 6mm did the job fine !:yes:
good advice garretridge.You can purchase the fastset from any builders merchants or from b and q.
uneven walls
saintdom,
brian c,
saintdom,
brian c,
