Discuss Tile backer board, which brand do you recommend? in the Tanking and Wetrooms Forum area at TilersForums.com.
Boggs
I tried the foam, couldn’t get on with it.
Waluigi
Foam takes some practice. Once you get used to using it and the little tips you pick up, it’s really good. I though it was a nightmare the first couple of uses but I’m a convert now. It replaces gripfill too.
Andyman
Not used gripfill in years
Andyman
Foam is able to stick studs to a wall but in this instance I was talking about a stud wall with the old plasterboard removed. The bare studs are then sprayed and then the new plasterboard is bonded on to them. Then screwed.
This is talking about bathroom walls which are rarely very big. If you have say a 6 metre long wall that needs making true then I’d look into other ways of getting it flat and Plumb. That’s another thread :)
Andyman
These stud walls are new, 75x50 tanalised and braced off existing wall.
Do you use backer board in the shower / wet areas ?
Always used Hardiebacker never had any come back & always crossed bond in to studwork 35/40mm yellow zinc screws I prefer the spax screws
Wayne Brown
I use thermo board from our sponsor wetroom store great valve for money and works well available in various thicknesses . Kop
IMG_20190415_103623.jpg IMG_20190415_115256.jpg IMG_20190415_165802.jpg IMG_20190426_124841.jpg
Reply to Tile backer board, which brand do you recommend? in the Tanking and Wetrooms Forum area at TilersForums.com
  • Poll
Teejay
