Sigma kera cut issues
Balloo
Hi guys I bought the sigma kera cut in 2015 with everything that comes with it about £1800. reason for buying was cutting 1800mm stone , I thought it was cheaper than to buy riamondi wet saw and I could use later for large tiles .
Well on a few occasions I've been trying to cut 1500mm -2000mm x10mm tile and with the sigma breaker they just wont break clean . sigma claim they can cut up to 10mm thick but I would dispute that
Which breaker are you using with the 10mm. The old type hand plier is no good on anything above 6mm in my experience. You need the wind up breaker for 6mm to 20mm.
Some 10mm are extremely difficult to break on the length.
I get a higher success rate with two people with two breakers at same time, tightened slowly at same time.
It’s not the system, it’s the tile.
The Raimondi freecut struggles with the same tiles. (Make)
A plank tile?
You’re not asking too much of it with thin cuts are you?
Not trying to be clever, just curious.
Do you break one end and then go to the other and break again?
I think the best you could hope for is around
50-60mm Off cut.
I did 150x20 with freecut,
no problem.
is the same as cutting a 120 cm.
you should not have any problems with casabella,
it is still florim ...
geoff, I'm not the man of the big format. 😉
I have a sigma kera cut ... bought to do 14 bathrooms on XL porcelain, but all the tiles were 3mm and 6mm thick. Never tried to cut 10mm tile with it.
Balloo,
Gus,
Balloo,
Gus,
