F
Fekin
Absorption rates are low on porcelain so leaving something on them for a few hopurs isn't really going to be a good tester.
Discuss Sealing Polished Porcelain Tiles in the UK Tiling Forum area at TilersForums.com.
I am fixing some Pilkington polished porcelain tiles soon and Pilkington Tech people recommend seal before fixing!Got the rough finish polished porcelain look on MY OWN tiles at home. My wife is now questioning my professional capabilities. Huh. Cleaned and sealed but they still look patchy. What sort of polish works the best, and should I use my light car polisher as I do for honed and polished travertine (better than an old towel)? The sealant (Lithofin's finest) does a class job on the grout especially if its a light gray, ivory or the like which shows up when wet. Sealing is a MUST on polished porcelain and unlike natural stone need only be done after grouting.
Are they kidding? How long for that job and how to price it? The problem I keep coming across is transit micro-abrasions, i.e very fine surface scratching caused by packing and transit. They do not disappear with grout and cement remover, sealer or porcelain cleaner. Nightmare.
What I seem to have on my own tiles is a lovely pattern caused by the sheets of thin expanded polystyrene used to separate the tiles in the box. Cannot shift the marks and the tile rep is at a loss too. Would be in the mire if I had supplied and fixed these for a client. As it is my wife........well you can work out the rest.
Help.
Thought that was the idea of sealing? Generally speaking, if you spill something on any floor, you would leave it longer than 3 hours before you clean it off. Treat a tile the same as carpet - if i spilt something on my carpet i would wipe it off straight away - same applies for a tile.
I agree, the longer the better, so i suppose overnight would be a good test.
Reply to Sealing Polished Porcelain Tiles in the UK Tiling Forum area at TilersForums.com
