Is this a BAD TILING JOB?
We are currently getting our whole house refurbished. The standard of the work as been very high so far however when it's come to the finish and attention to detail of the tiling in the Main and EnSuite bathroom, well, I think, even having never ever tiled before, after watching a handful of YouTube tutorial videos I could probably do better lol! It just looks like time hasnt been taken to give elements a good finish.
Main Bathroom has been grouted and grout is highlighting the roughly cut tiles. Worried that the same will happen with ensuite.
Is this considered a good job?
Would REALLY appreciate some feedback and opinions from tilers to give me more ammunition to go back to Building Contractor with.
IMAGES BELOW ....
Main 001
At the top of the tiled area slithers of tiles have been added to take up the space left before the metal edging. When this was realised shouldn't tiler have set the whole tile to the top and the slither down at the floor. It's also really scrappily cut.
Main 002
Metal edging at corner has razor sharp edges with a small sharp burr too.
Main 003
Around the shower and bath niches the cut of the tiles against the metal edge is very ragged, especially exaggerated by the contrasting grout. Metal edging not aligning either - something I highlighted with billy a while back but he assured me the grouting would fix.
Spacing
The spacing of the wood effect tiles is not consistent between the floor and wall. The floor has a lot less than the wall. We had hoped the black grout would be a feature of this tiling but it is not noticeable on the floor.
EN 001
EN 002
Cutting of tiles is really ragged around the edges of the niches.
EN 003
Tile selected for top of niche has off-vertical angle cut on right hand side which will result in a wide area of grout needed here which will stand out. Angled gap inbetween metal edging too.
EN 004
The central tile thats been cut or selected for the centre of the niche has 1/4 inch gaps either side.
Strangely in stark contrast some tiles we have elsewhere in the house have a razor sharp cut rather than a ragged edge. Would this be down to the fact it was done by someone else (with a sharp tool?!) or the tile type?
Yes, it’s bad!
There was a little hacksaw like this left beside his tiling gear which I assumed he'd been using to cut tiles. I ran my finger down the blade to see how blunt it was .. and yup it was!
@Localtiler
I see it now, the mistake too is the extra metal spacer that's had to have been added to make everything fit. Besides the rough edges an uneven spacing.
Yes.
Picture 2......he has started with a full Tile hence the extra horizontal piece of trim.
Then again if he had put a cut in......it would have looked like some of your other raggy cuts.
@Localtiler not necessarily an inexperienced tiler, I have seen many an experienced tiler produce work like this.......I kid you not!
It’s terrible. Also can I why in picture 1 pink board (fire) has been used but next to it is mr or acoustic board (can’t see from pic ) is it what they had left over or is there a reason
The tiler in question either hasn’t got the appropriate tools or he does not have any pride in his work, the ragged edge of tiles could be rubbed down with a diamond pad. Also with the trim work maybe he needs a new mitre block.
I agree. Depending on tile. No need to use a grinder or wet saw. Dry cut and it would look lovely
Probably just what was left over. We are covering this entire piece of wall with a big mirror anyway, it's not being tiled or painted.
I always go to score and snap on finished edges if possible and scribe in at back with a grinder (covered with Silicon etc )
What tiles were they OP?
Do you mean Porcelain or Ceramic?
Or just in general what tiles they are/where they were from?
I do know that the Wood Effect floor tile is from B&Q - I believe it is this one - so a Porcelain tile.
Are you asking as this might have an influence on how well the tiles could be finished? i.e. cheap tiles will chip easily like this when cutting?
**** poor effort there mate stop em now ! that is no way acceptable any tiler with any pride in his or her work would turn out rubbish like that. Kop
We are meeting with the boss of the building contractor company on monday to go over the tiling work (and other things).
I couldn't live with the crapness of this job even if a discount was offered so it's going to be a "start again please...".
That workmanship is BAAAAAAADDDD!
It is probably one of the worst we've seen for a while and there have been some corkers.
As the other's have said, stop the tiler and do not let them continue
burger,
CJ,
burger,
CJ,
