TilingPeter
I got a cheap wet saw after reading good reviews and the results are disappointing. It's a 750W Erbauer one and it leaves a lot of chipping.
One of the biggest issues I have is with breaking the corners of my tiles. They are 300x600 and there's a lot of friction between them and the table. I notice that the tile does come away from the fence slightly at times which can't be good. One of the biggest issues is the last bit breaking. I'm guessing that the different sides of the tile are trying to move at different speeds and breaking the last bit. Is a rail saw likely to solve this problem as there will be no friction?
I tried a new blade but the chipping is very similar. However, I could only find cheap ones stocked locally. What would be best? Should I get a rail cutter with a good blade? Would a Rubi DU-200L-BL give a good finish? I don't need many features, jut a clean accurate cut. I don't mind paying a bit extra for a good cut but I don't want to pay loads of money for the same as I'm getting now. I do need to do a number of 'L' shapes, so a straight cutter won't be enough.
Would a good blade eg. Rubi fix the chipping? Most of the chipping is less than 1mm, but a few bits are 1-2mm.
