marko56
Am about to tile my corner shower enclosure - one wall aquapanel, one skimmed - I've tanked both and am using 500 x 250 ceramics with bal supercover rapid flex - my problem is with the skimmed wall - I knew there was a slight bow in it but having used a decent length spirit level I now realise it is worse than I first thought - basically if I use 2/3 mm of adhesive at the bottom and top of wall I would need to use about 8 - 10mm half way up to keep everything true - I need to tile to the ceiling because I've tanked to there. Bal instructions say adhesive can be used up to 12mm in depth for localised area but when I phoned their technical dept for advicse he advised against this because of the risk of shrinkage of adhesive and ultimately tiles falling on me head:yikes:. The area that needs this depth of adhesive is from about 0.75 m high to 2 m high. I await and deserve any abuse that comes my way:lol: and any advice if possible!
