Discuss How do you guys get fix tile trims perfect in the Canada area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
Tile trim...
how are you guys getting it perfect?
Do you prefer to set your trim the standard outwards facing way or face it in?
do you put you trims on before you tile and cut to the trim?
Thanks!
Tile trim...
Thanks!
personally, I like to level them up, tape the trims into position and measure up perfectly.
I'm sure others will tell you differently.
Not sure what you mean which way they are facing mate?
Thats what i think would be best, put trims up first nice and level and then tile to them.
normally cut tiles first then trim in after which i personally think takes longer cause i have to polish the edges perfectly clean.
the image I’ve puton is the trim facing inwards mate
Aaabbb
The standard way is the only way to put them on , as the grout will crack and are not waterproof the other way .
Reply to How do you guys get fix tile trims perfect in the Canada area at TilersForums.com
Dawz84
