Discuss Tiling on mapei renovation screed in the The Welcome Forum area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
Preferably a C2S1 but a C2 would be fine. What type of tiles are going down?Hello everyone
I am new to this forum and need some advise. What flexible adhesive is best to tile on mapei renovation screed?
Ate you sure you didn't put too much water in your levelling mix , so you have a laitence on top which is separatingfrom the levelling and not the adhesiveWould be travertine tiles..wunda insulation boards,16mm pipes, and then tiles. Tested with ultratile Proflex s2 came off, then did primer mapei eco prim grip, Proflex s2 on top ... same. Thinking maybe need switching to different brands, avoiding expensive mapei adhesives (flexible) ?
Yes I'm sure 4l of water per bag as manufacturer states.Ate you sure you didn't put too much water in your levelling mix , so you have a laitence on top which is separatingfrom the levelling and not the adhesive
Do you have a picture of the back of your rest tileYes I'm sure 4l of water per bag as manufacturer states.
[automerge]1578997764[/automerge]Do you have a picture of the back of your rest tile
Your test is still unfair as to amount of force you are applying to a small area ,Thank you for advice..today I'm going to prime it with mapei G and see how it goes..
I did similar test with same adhesive just directly on wunda insulation panel...you need a hammer to take it off...solid as a rock. It looks like this ren screed so smooth or greasy that didnt stick, not penetrating into surface just sits on it. Better I avoided it doingYour test is still unfair as to amount of force you are applying to a small area ,
See now I kept away from wundaboard advice as I have no experience in itThe eco prime grip is supposed to go onto the top of the wundafloor boards prior to tiling.
You can stick the underside of the wundaboards down to the levelling compound with any c2 adhesive.
Are you a tiler or a DIYer, if you do not mind me asking as Wundafloor will only guarntee the floor using their tested method which is using Mapei adhesives and primers.
I have just tiled one before Xmas and it was a total **** up with the people who laid it.
One more point - you will need a crack mat on top of the wunda boards too as it is Travertine that you are fixing.
Good job I know what I am doing!!!
Reply to Tiling on mapei renovation screed in the The Welcome Forum area at TilersForums.com
