Tiling on mapei renovation screed
Would be travertine tiles..wunda insulation boards,16mm pipes, and then tiles. Tested with (Brand Blocked Temporarily until they unblock us on facebook) Proflex s2 came off, then did primer mapei eco prim grip, Proflex s2 on top ... same. Thinking maybe need switching to different brands, avoiding expensive mapei adhesives (flexible) ?
Ate you sure you didn't put too much water in your levelling mix , so you have a laitence on top which is separatingfrom the levelling and not the adhesive
Firstly I don't think allowed enough time for the adhesive to develop strength as shown by the adhesive separating and I wouldn't of use that primer in that situation , I would of used primer g . I would fancy that is just going sit on top of the levelling and not really bond into the surface , I'm not going to check but its really meant for non porous surfaces
[automerge]1578999031[/automerge]
Also I would say that I a hard test as the if you multiply force you've applied to the tape to pull it up to a square metre It would be collosall
Just checked they it's ok , but they do say well cured , typically for adhesive manufacturers they are ambiguous are their instructions but to be honest I still wouldn't use it because I think it will just peel like a lot of brush on tanking products will
Your test is still unfair as to amount of force you are applying to a small area ,
I did similar test with same adhesive just directly on wunda insulation panel...you need a hammer to take it off...solid as a rock. It looks like this ren screed so smooth or greasy that didnt stick, not penetrating into surface just sits on it. Better I avoided it doing
The eco prime grip is supposed to go onto the top of the wundafloor boards prior to tiling.
You can stick the underside of the wundaboards down to the levelling compound with any c2 adhesive.
Are you a tiler or a DIYer, if you do not mind me asking as Wundafloor will only guarntee the floor using their tested method which is using Mapei adhesives and primers.
I have just tiled one before Xmas and it was a total **** up with the people who laid it.
One more point - you will need a crack mat on top of the wunda boards too as it is Travertine that you are fixing.
Good job I know what I am doing!!!
See now I kept away from wundaboard advice as I have no experience in it
A an unregistered reader is doing the same thing here.
Hamlet 79,
Dan,
Hamlet 79,
Dan,
