SLC over a heat mat......
Andy Allen
What you lot using to cover your heat mats...??
I'm struggling to get hold of my normal Weber floor flex...
Also, talking to my supplier he was working out for a 23m2 floor I would need 7 bags ?
I normally work on getting 2m2 per bag...?
Me too
Generally use Ultra rapid leveler, or TM Rapid 30 over wires if in a rush, if no rush the two part Ultra leveler.. There's some good prices if you shop about, might have to buy min of ten bags for free delivery though.
Same Andy or thereabouts 2sqm per 20kg bag at 6mm..
Keep hearing good things about the level flex 30 how dose it compare to the stander level flex...which I can get £2 a bag cheaper !
Is it still easy to use....?
Keep getting vision's of it going off before get chance to level it..
Its fine at this time of year, just gotta be all set up with plenty of water at the ready in the summer and don't stop mixing and pouring till whole floors done..
For leveling over ufh i use 1" strips of 6mm insulation boards, stuck to level or flat with ady and split floor into 1m wide runs over ufh mats, just pour a load in at one end and pull 4ft level over strips...
I use Tilemaster fineflow 3000 because it flows and is one of the cheapest around. Setting time is on the slow side and is a minus point.
Mapei Renovation screed is also excellent for the slow setting variety.
Mapei recently already have a rapid version, Ultraplan Maxi
I usually use bal level max but used mapei renovation screed on my last job. They are fairly similar, but mapei seemed to flow a little more.
I have used both recently,depending on which was on offer at the time. But at low thickness levels I wouldn't call them 'self leveling'
I tend to use Ultra 2 part if I can wait over night but i can highly recommend Topps fast track if you need a rapid setting slc.
Easily walkable within 45mins every time I have used it.
I've used a lot of levelflex but I don't really like it, doesn't flow and never seems to set that hard
Andy Allen,
Flintstone,
Andy Allen,
Flintstone,
